starter
Old Sep 3, 2017 | 02:52 PM
scarecrow 82's Avatar
scarecrow 82
Stage I
Default starter
starter labors sometimes like a low battery sometimes starts no problem,now its whirring had to disconnect battery to stop it when i touch pos wire to batt it starts whirring again, new battery and solanoid just had engine rebuilt last fall (top end)1500 mi. ago.has been fine, problem started slowly but kept getting worse now bad its an 82 shovelhead fxe customized
Old Sep 8, 2017 | 06:07 AM
grbrown's Avatar
grbrown
One possibility is that the wiring to the starter button on the handlebars is damaged, or the switch itself is faulty, so it is staying permanently on (as if you are holding the button down). Check inside the handlebar switch console for damaged wires, or wires touching each other.
Old Sep 12, 2017 | 08:09 AM
bustert's Avatar
bustert
that sw is low power but a possibility
sounds like a stuck solenoid, high current and are prone to failure, nature of the beast. just remove wire off it from start button and turn power on, starter still goes to town, found your issue.
Old Sep 15, 2017 | 03:38 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Charge the battery and have it load tested.
A weak battery can be the cause of starter run on.
You need to determine if the battery is good before you attempt troubleshooting the starter system.
Old Mar 19, 2021 | 04:26 PM
Mikecannon1222@gmail.com's Avatar
Stage III
I have the hole right side disconnected and the power is still there
Old Mar 19, 2021 | 05:47 PM
Dan89FLSTC's Avatar
Dan89FLSTC
This thread is long dead.........
And your post makes absolutely no sense.
If you are looking for help:
Start a new thread.
Give model and year.
Tell us exactly what the issue is.
busterman2
EVO
14
Jun 20, 2012 06:18 AM
vetto
Feb 26, 2010 05:29 PM
Burzum
Jul 16, 2009 10:30 PM
dirtyboy
Ironhead
16
Jun 7, 2009 05:45 AM
84sugar
EVO
Mar 23, 2008 11:46 PM
