Is there a kit or wiring diagram to follow to allow the passing lights to remain on during high beam operation? I have checked the major parts vendors for Kuryaken and Custom Dynamics harness adapters and didn't find anything. Any help is appreciated.
You can disconnect the Aux light power wire from the low beam at the headlight connector and wire it into the fender tip light connection (O/W wire) on the left side of the frame below the tank. That will give you always on operation when the ignition switch is in the ignition position.
