Fender light off with acc
10-11-2017, 03:28 PM
I have a 13 limited and had the accessories fuse blow the other day. Replaced fuse but now fender tip is off when switch is at acc. Everything else seems correct just that light. All is fine with ignition on. Any suggestions?
10-11-2017, 03:30 PM
Are you 100% sure it came on with "Acc" before?
10-11-2017, 03:34 PM
I can not say 100% but about 95% sure. My 05 heritage was always on when in acc for sure. I thought it was on this bike also. Maybe I am wrong?
10-11-2017, 03:38 PM
Not sure either, but other than something in the ECU, I can't think of failure point for the symptoms.
10-11-2017, 05:36 PM
Maybe someone else will respond that can answer indefinitely. I thought the front turn signals and fender tip were on with acc but maybe I am just remembering my old bike
10-11-2017, 05:55 PM
The fender tip lamp is on the Accessory Circuit.
10-11-2017, 06:18 PM
That's what i thought. Just can't figure it out. It works fine when bike is running
10-11-2017, 07:06 PM
Check the voltage at the accessory fuse, with the switch in Acc position and also Ign position.
10-11-2017, 07:31 PM
My passing lamps and radio still work in acc. I have the kit so my passing lamps stay on when my high beam is on
10-11-2017, 07:57 PM
Check the voltage at the accessory fuse, in both switch positions.
Systematic troubleshooting, with voltmeter.
Unless you just want to guess...
