Turn signal/brake issue
I tried swapping the tssm with a friends module. My bike is 2009 and his is 2012. Same results. Tried the brake relay and lighting relay as well from his bike. I also tried installing a triple play with no luck. This all stemmed from replacing rear fascia and lights with CVO style lights.
Doesn't work like that, tssm has to do a password learning proceedure when you swap either the tssm or the ECU. If the bike just had a TSM and you were swapping a TSM between the two bikes no issue. But again I say it sounds like the add on module is at fault and not the tssm.
Mark (Rooster)
05-14-2015 12:17 PM
blz2503
05-20-2009 07:59 PM
