Rear Blinker Housing Tests OK But Bulb Won’t Light
Added Tailbones to my 2006 Dyna Super Glide, to make rear blinkers driving lights and allow them to flash. I added Kuryakyn rear leds and equalizer which flashed just fine. The leds were the kind you install like a bulb, insert and twist. When I added the Tailbones and the right rear blinker was out. After testing wires, TSSM, and handlebar switch with tester all tested good. I then tested the blinker socket it lights the tester ok but when I put original bulb back in it does not light up, tried bulb on left blinker it is a good bulb. I’m not sure what is happing here, could it be a bad ground on the socket? How do I take blinker socket apart?
