Installing a voltage meter
I have a 13 Fatboy, trying to find a wire in the console to run a the positive voltage meter wire off of. Everything I am finding is either on constantly with the ignition off or only runs at 3 or 4 volts. Anyone have a suggestion or wire diagram?
Even the ignition white/blue wire only runs at 3 or 4 volts and is a constant which does not make sense to me as it is an ignition switch
right off hand, i would look at the lighting system as it would be 12v and powered off when key is off, i believe it to be a red/orange
google harley sip and then pick language and you can find schematic, a lot of info can be had by inputting vin number.
https://serviceinfo.harley-davidson.com/sip/index
Wrencharound
10-30-2017 07:33 PM
