'80 FLT electrical issue
Hey fellas. I've been rebuilding my dads bike and have it all back together and went to start it up and I have no spark. The instrument panel (not stock) isn't working either but I'm not sure if that's related because all other electrical seems to be working.
I had to put in a new voltage regulator because a short in the wire fried the old one and I also replaced a bad stator. I tested the coil and it has good voltage coming out of the secondary side. I'm at a loss as to why I have no spark or no instrument panel.
Would this be the part you are talking about? It's all one piece with no connectors off of it
I just got home to find this grim sight. That's the wire that comes off the regulator to the breaker. It's obviously toasted along with who knows what else. I clearly have a deeper problem here...
Been on the bike for only a week...
the ignition is an original hard wired unit cant believe one is still installed
the voltage regulator hot wire shorted so a new system should be installed - reg and stator with the drum - convert it to the 32 amp evo unit and you will be good for a long time
ultima ignition is a good one but the coil that comes in the kit form is junk have a bucket of new uninstalled - sure someone will say they have one lasted 50,000 miles in a bike but they never lasted when we installed them
