Regulator update
Old Apr 17, 2008 | 09:40 AM
riden2low's Avatar
riden2low
Default Regulator update
I had a question about my regulator on here and got a few answers but since I have a Crane h4e, I called Crane they were saying that the Crane ignition is so sensitive that it needs the proper voltage to work. Now I have change back to my old ingnition andthe bikeran fine. Crane told me that the stock ignition was more forgiven. So started checking my regulatorby doing all of the test and everything was fine but I did find the plug from the regulator was only half in...So I put Crane back in and it runs fine......So I had purchased a bracket that holds the plug in it's place but found out veration it will loosen up. I retighten but I think the plug has had it as it doesn't take much to pull it off. But the thing is that the Crane is a good ignition but very sensitive to voltage change. So I hope this infro helps someone if they run into the same problem............
luftwaffe
Nov 25, 2012 07:16 PM
willjob
Sep 6, 2012 03:26 PM
harley_guy1995
May 23, 2012 10:46 PM
babyray
Apr 20, 2011 05:28 AM
JohnnyBravo
Oct 8, 2009 06:33 PM
