Stator / Rotor question
2012 Ultra Classic 57K miles.
Thanks guys.
testing makes sense. when my stator failed due to a bad connection at the winding to pigtail, that is what i replaced since there wasn't enough winding lead to remake the connection. i still have the original VR from 2001. as far as the rotor, if the magnets are secure, no need to replace.
start with a good fsm or electrical manual. there is plenty of online help.
A quick simple check is monitoring the battery voltage during cranking to see if it is dropping below 10 vdc; monitoring the charging voltage after starting to see if it is at or above 14 vdc, and checking the output of the stator to see if the output is ~16-26 volts AC per 1000 rpm depending on the amp rating...
This is fun with someone else's money.
I had an intermittent stall on carbed bike. replaced CPK, than map. Coil tested good. But stalling stopped when replaced. So dont get hung up on it has to test bad, Had 45k, so I didn't mind wasting $45 per sensor.
There have been several issues diagnosed and repaired, some never traced and parts/money thrown at the problems. It's a long LONG story but currently the recurring aggravating issue is the left turn signal turning itself on and not wanting to cancel manually unless I hit right signal. Left signal also sometimes won't activate when I want it to. This turn signal problem has happened before and was never actually diagnosed or fixed, it just stopped doing it and the one possibly related issue I fixed was bad ground at the stud on the transmission from the cable that merges with the main battery ground at the ground stud. It appeared the wire was never soldered or crimped into the terminal with the battery ground cable and wiggled itself loose after 10 years and for a long expensive while before I located it, it would sometimes stay connected and sometimes not.
That cost me 5 trips to shops, 2 of those to Harley, and none of them found it but I did a couple days after the 5th time getting the bike back and breaking down and having to have it towed. Now this recurring left turn signal ghost is getting me again. All the sensors on the bike are new as is Harley voltage regulator and Harley ignition coil and Harley starter (this was verified bad) and new battery (also verified bad). Battery and starter went bad at seemingly same time right in the middle of the second round of really low fuel pressure (I guess unrelated to electrical issues) so just 2 days ago I put in new tank guts, new starter, and new battery and all the other new parts were in the last month or 5 weeks.
Anyway, this left turn signal ghost seems to happen after I ve ridden a lot of hours for 2 or 3 days when it's kinda hot out, over 85 degrees. I road about 4 hours Saturday after fixing the fuel pressure problem and installing battery and starter, about 9 hours Sunday and about 3 hours today. Today after running around 55-70 mph for 1-1/2 hours and got into a town and had to slow down and do the stopping and starting usual to driving in towns, that is when the left signal ghost returned. I don't know what to do next. I'm starting to wonder if it could be a heat related issue with the stator or defective new Harley regulator?
I have appointment with Harley Wednesday to check the ECM and regulator and hopefully do full diagnostic check but I was wondering do you know if their machine and that box I've heard talked about hooking up to the electrical harnesses, can their testing equipment easily check for and verify electricaal sensors problems and regulator and stator and all else or are they going to take forever and charge me a fortune? Thanks for any helpful info if you get this before I take my bike in Wednesday and have a chance to respond.
