Speedometer Wiring Issue
A short in the speedometer would not cause the cable to get hot, it would cause the wire between the speedometer and the fuse to get hot...
The problem is a bad ground...
The speedometer has a black ground wire that should be connected to the upper fork bracket, if this ground is bad, the voltage will simply find another way to return to the battery, in this case it is running through the cable until it gets back to ground.
Trailblocker
Electrical/Lighting/Alarm
05-01-2014 01:38 PM
