Not even clicks
Well, it is somehow back to no crank again. After I got it to "not turning over but no start" I tried to figure out the no start part. I check battery voltage its 13.4v. Battery is brand new-hasnt been fired up once and checked with another battery. I check for fuel. About a gallon in the tank. Fuel out squirts out carb nozzle normally. Go to check spark plugs(see they are black as **** in spite of only be fired up for a total of maybe 90 seconds before the bike died on me as it was warming up weeks ago). Before I put the new plugs in I decided to check compression. Got damn near dead nuts 120psi on both front and rear. Put new plugs in to check for spark and then she doesnt want to turn over again at all for the spark plug check with the little plug tester. I have all lights, horn etc. Im at loss
The Red w Black Stripe wire is not the problem, this wire is always energized, the power for this wire comes from the ignition switch.
If the fuse blows when you press the start button, the problem is in the wire that goes between the start switch and the start relay (or it could be the switch itself, but not likely). The wire is black with red stripe.
Have you had the handlebar switches apart lately?
