2008 FXDL turns not working with load balancer
As I stated above I bought a hogworkz low pro led taillight with integrated turns. I also bought their load balancer with it. When I just plug the tail light in the running light and brake work correct. When I hook the turns up the light lights up yellow and stay on. They will flash like they are supposed to but when you clear them the light still stays full yellow. I have the load balancer in line and have the correct harness they provided with it. I have also tried the balancer on the high and low settings. I have correct turn signal wires going to correct sides and have grounds capped. Im pretty much at a loss at this point. Any help is appreciated
