Wiring Tail light
Old Apr 24, 2012 | 10:07 AM
emperor wurm's Avatar
emperor wurm
Default Wiring Tail light
So as I said before my stock brake light fell off, I am installing an led bullet light that I believe was a turn signal for a deuce or something, I bought it at the swapmeet. The LED's are orange, but it has a red lens...whatever. Anyhow, I needed to know if I need to install a resistor to have the LED's function normally? I am just running this light as a brake light only. The light has three wires coming out, black, red, and yellow. I am assuming I can cut the wires out of the harness and solder the brake light directly in without a resistor, Can anyone let me know for sure? Thanks.
Old Apr 24, 2012 | 11:18 AM
streetfighter06's Avatar
streetfighter06
I wouldn't see why not. I ran an led light a few years back when I had a fender and it worked without any issues.
Old Apr 24, 2012 | 11:22 AM
emperor wurm
sweet, do you remember if the light had three wire? or two? Mine has three (red, yellow, and black) from what I have been reading everything with the yellow wire is for the RH side turn signal.....do you think I can use the yellow wire as the dim/running light?
Old Apr 24, 2012 | 11:40 AM
streetfighter06
Idk. Mine was a plug and play. Doubt you can get it to work as brake and running. Play with the wires. I'm no electrician. That's what I always did and blown some fuses along the way....
hhkiwi
Apr 15, 2015 03:41 PM
wickiupwarrior
Electrical/Lighting/Alarm
May 28, 2013 11:20 PM
FLYING_BURRITO_BROTHER
Nov 13, 2012 04:44 PM
RatBob13
Nov 10, 2012 10:37 AM
GlassBikerNC
Sep 13, 2007 01:29 PM
