Tail Light wiring
Could you post some images?
In general I can say:
Types of bulbs used in taillights are:
- Dual filament for brake/tail light 20W/5W
- Single filament 20W as brake light
- Single filament 5W as tail light
- Festoon bulb 3-5W as a tag light.
Color codes to use on a Dyna 2004:
Blue for running/tail light and tag light
Red/yellow as brake light
Black to ground
Here's in image I posted some time ago on how to wire a double filament taillight:
Some points to check out:
- check with a probe light or a multi meter if you have any power coming from the brake light signal wire
- check if the brake signal wire is connected properly to the lamp fitting
- does the double poles make good contact in the lamp fitting
- is the bulb OK?
- are the fuses OK?
