Need help with hid ligths
Not to hijack this thread but I've got the DDM TUNING 55w Hi/Lo kit and be damned if I know how to hook it up on a FATBOY LO... anyone got experience with this? I've watched videos and read the install instructions. One person tells me to hook it up to the stock harness but then why do I need the power and ground wire if I do that... I know bulb to ballast, ballast to harness... they still is something wrong though. Anyone got a step by step on a Fatboy install?
Bear. from what I can see in the instructions;
1. unplug the old bulb from the factory wiring harness
2. remove the old bulb from the headlamp socket
3. insert the new bulb into the headlamp socket
4. plug the ballast into the existing factory wiring harnesss plug from step 1 above.
5. mount the ballast somewhere out of the way
6. connect the red and black wires from the wiring harness directly to your battery for the red and a good solid ground for the black
7. plug the red and blue wires from the bulb into the ballast
this should be it.
The reason you need to connect the power and ground in addition to the stock harness is because the ballast draws quite a bit of current (amps) and your stock harness is not capable of supplying that current. The factory harness basically acts as a low voltage/current "trigger" for the built in ballast relay when you flip from high - low beam to allow voltage across the circuits directly from the battery.
this should be it.
oh you're talking about the grommet at the back side of the headlamp bucket itself! duh.. sorry bout that. you'll need to work at that one.. you should be able to open the grommet up enough to get the black and red wires through it with no problem. if not, enlarge the hole in the bucket, go down to radio shack and get a new grommet that will fit your hole and wiring.
