Sliding down the slippery slope - 107 build
I will be gathering components for a 107 bagger build on a 2010 SG this year and would like to know those with experience on their top (3) cams they would consider their short list. My riding style is probably 70% solo and would like the power to come on under the curve (low-mid) torque cams. I am not interested in peak numbers because that is not the range or rpm in which I ride. I am guessing compression should be around 10.5 to 10.8 area.
I would like to see 115+HP/ 120+TQ (Is this feasible?)
I already have Zippers MaxFlow, D&D Boss Cat exhaust, TTS tuner and Woods TW6 but, I don't think just doing a BB with these components will get me there.
Will I need a larger throttle body, injectors and does the crank need to be Hobanized?
Thank you....
Thank you....
Go to http://www.fuelmotousa.com/107-inch-big-bore.html and read to your hearts content. Many folks here have used him. Hillside Cycles is another good one.
Thank you....
Thank you....
Our Stage IV Heads, 55 HPI, Fatcat.
Hits hard off the bottom and then the heads let it run out the back door.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
