Need more power from my 107
Old 06-29-2015, 03:23 AM
Ride my Seesaw's Avatar
Ride my Seesaw
Ride my Seesaw is offline
Received 1,590 Likes on 741 Posts
Default Need more power from my 107
Last summer I had my 2010 SG engine spiffied up with a Head-Quarters 107" kit. Unfortunately what was once enough 'giddy up' is now no longer the case, I need to feel more power. Right now I'm getting a respectable 121 Tq and 115 Hp with their head work and cam, all else is stock. Would any of you engine gurus know if going to a larger throttle body or bigger injectors would give me much if any greater gains? In hindsight I should've just gone with an S&S 124 but for now I'm on a budget and want to know if I can RELIABLY squeeze more power from this 107?
Thanks in advance.
Old 06-29-2015, 03:48 AM
Tat2u's Avatar
Tat2u
Tat2u is offline
Depending on your heads You could go a larger TB & change cams to a 625 for example and you might increase hp but you will probably lose tq at the same time or at least not gain any torque ....
If you are not happy not more cubes is probably the way you will have to end up going.
Old 06-29-2015, 07:26 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
A 55mm HPI with an 1.800" intake port, and match the cylinder head port ID to that would be my thoughts.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 06-29-2015, 09:41 AM
Primetime_2's Avatar
Primetime_2
Primetime_2 is offline
sounds like to me you are the kind of guy that needs the bottom end built as well! especially if you wanna throw more at her!
Old 06-29-2015, 10:01 AM
djl's Avatar
djl
djl is offline
Received 2,069 Likes on 1,523 Posts
Originally Posted by Ride my Seesaw
Last summer I had my 2010 SG engine spiffied up with a Head-Quarters 107" kit. Unfortunately what was once enough 'giddy up' is now no longer the case, I need to feel more power. Right now I'm getting a respectable 121 Tq and 115 Hp with their head work and cam, all else is stock. Would any of you engine gurus know if going to a larger throttle body or bigger injectors would give me much if any greater gains? In hindsight I should've just gone with an S&S 124 but for now I'm on a budget and want to know if I can RELIABLY squeeze more power from this 107? Thanks in advance.
Ahhh, buyers remorse huh? I hate it when that happens! Sure, you can go bigger on the T/B, etc. but the increase will be marginal and probably won't even register on the butt dyno. Enjoy the power that you have, save your shekels for the S&S 124.
Old 06-29-2015, 01:14 PM
Next In Line's Avatar
Next In Line
Next In Line is offline
Drop down 2t on your transmission sprocket.
Old 06-29-2015, 03:11 PM
Tat2u's Avatar
Tat2u
Tat2u is offline
What actual head work was done?
Old 06-29-2015, 08:57 PM
HD Bobber's Avatar
HD Bobber
HD Bobber is offline
Yup that was my thought as well. Probably the biggest improvement you can make that you would feel.
Old 06-30-2015, 01:31 AM
Ride my Seesaw
Not exactly sure on the specifics for the TwinCam 107 kit, the work was done about 3000 miles away at head-quarters.com and shipped back to my builder here on the west coast. Here's what their website states about their head work,
High Velocity Ports (HVP) Spin Dropped Heads
This picture illustrates the work done to all stock Twin Cam heads used in our kits, or as done to your own heads when sent in for work. We have removed the valves to show the workmanship
We also ship the appropriate thickness head gaskets out with all jobs to ensure proper piston to head clearance.
- finished heads will have a combustion chamber volumes calculated and machined to yield the desired compression ratios
- we can also adjust the cc volume on special order heads to accommodate different pistons
- can be setup for use on 88", 95",103" or larger engines with varied compression ratios
- for use on carburated or fuel injected models
- heads are fully ported, decked, and have a fully radiused valve job
- they contain new valves (1.900" & 1.625"), guides (manganese bronze), springs (titanium top retainers), and seals (Viton)
These HVP heads are supplied with all of our performance kits
Old 06-30-2015, 01:50 AM
Ride my Seesaw
Is this something I can do myself with a $39 socket set and a torque wrench, I assume I would need to recalibrate the speedo too? Are there known part numbers for the smaller tranny sprocket, and (I'm guessing) a shorter belt too? This sounds like the direction I want to go, am I losing anything at the top end of the 6th gear's speed range? Is there a negative side to doing this?
Thanks for all the help and input guys!
Quick Reply: Need more power from my 107
