Cams ,Yes or NO
Cams ,Yes or NO
I have come up with 3, bolt in ,low to mid range cams.
1.SE 255
2.Andrews 48h
3.Woods tw222
Bike - 2009 flht Electra Glide Standard, stage 1 , 96 cube . (No other engine mods). Tuner - Power Vision with narrow band auto tune..
Riding style is , solo,, 90% country and highway riding,, never see 5000 rpm..
The question is , if I had the three bikes , ( same as above), and installed each bike with different cams, would I, with seat of my pants dyno, be able to feel any real difference between the three cams in performance ??
After researching, I just can't pick between the three.. I need a bit of a nudge by you guys !!! Or should I get the best deal on any of the Three ?
Cheers ...
1.SE 255
2.Andrews 48h
3.Woods tw222
Cheers ...
They'll all work good.
2nd 48 install here in the past 5 working days.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
First off, you asked about seat of the pants feel. I would dare anyone to be able to tell me the difference in riding a bike with a 48 or a 255 seat of the pants. You might see some slight difference on the dyno but even very little there on a 96 inch motor. As for hard hot starts with the 255, in a 103 application yes, in a 96 not at all.
I have installed a bunch of 255's in 96 inch bikes and it makes for a really nice inexpensive upgrade. If money is not that big of a deal and you don't already have a set of 255 cams on the cheap then I would still probably run the 48 as it is a better cam should you want future upgrades.
Thanks for your responses guys .... Ok, with the advice above, I am leaning to the Andrews 48h ...
Question to Hillside, and other engine builders.. Bike, (as mentioned above), has done 110,000 kms ,(approx 70,000 miles).. Has not missed at beat,, oil consumption is normal,, compression test good,,
Plan is,, New cams,, replace cam tensioners and inner cam bearing,, new lifters,, adjustable PR's ,, new gaskets and orings etc,,
To keep costs to a minimum,, in your opinion, would it be advisable to reuse, cam plate,, oil pump,, and chains , if these components look ok after inspection ??
Cheers ...
Cheers ...
