Twin Cam 88" build-Cam questions
Andrews 21, or an S&S .509, are the 2 we install here for very good power in plug/play only set-ups, in 88" engines.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Early in this thread it was stated that the OP would need conversion cams. I looked at the S&S website and it appears the cam plate he has uses the early style (pre 2007) cams but has the updated hydraulic tensioner set up.
Easy way to find out. If you see roller or ball bearings pressed in the cam plate, early style cams.
Just an observation but I might be stating the obvious. Should open up the choice of cams.
Garrman
Garrman
The OP also has the benefit of the improved heads that were introduced in the '06 model year; no need for springs and head work for a cam only upgrade.
Early in this thread it was stated that the OP would need conversion cams. I looked at the S&S website and it appears the cam plate he has uses the early style (pre 2007) cams but has the updated hydraulic tensioner set up. Easy way to find out. If you see roller or ball bearings pressed in the cam plate, early style cams. Just an observation but I might be stating the obvious. Should open up the choice of cams.
Garrman
Garrman
"do i order a cam that is for a 96" TC motor since i upgraded the cam plate to the 07+ oil pump and plate?
The original post is a bit ambiguous. The OP states he replaced the stock cam plate and oil pump with an S&S unit. While he does mention 07+, I looked on the S&S site and only saw 99-06 cam plates that retained the outer cam bearings but used the later style tensioners.
It is possible I am mistaken but it appears the S&S TC3 cam plate for 99-06 still uses pressed in outer bearings.
Garrman
Garrman
The original post is a bit ambiguous. The OP states he replaced the stock cam plate and oil pump with an S&S unit. While he does mention 07+, I looked on the S&S site and only saw 99-06 cam plates that retained the outer cam bearings but used the later style tensioners. It is possible I am mistaken but it appears the S&S TC3 cam plate for 99-06 still uses pressed in outer bearings. Garrman
The OP should clarify the OP if he wants to get accurate advice on cam selection as some cams are not available as conversion cams.
