How the F%$#.....
Old Apr 13, 2017 | 07:21 PM
Aquadan005's Avatar
Aquadan005
Question How the F%$#.....
So I just started tearing down my Wide Glide, (doing a thorough rebuild) and came to the part where you take off the cylinder heads. With the amount of space given, how in great Zeus' butthole are you supposed to torque them down when it's time for reassembly ?! I should mention it's an 82 shovelhead.
Old Apr 14, 2017 | 04:45 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Is that info in your HD service manual?
Scott
Old Apr 14, 2017 | 05:01 AM
Iceman24's Avatar
Iceman24
If you're doing a total rebuild, why don't you have the motor off-frame and on stand/bench? Full access all around...
Old Apr 14, 2017 | 06:04 AM
prodrag1320's Avatar
prodrag1320
(???),never had any problem torqueing heads with the motor in the frame (any model)
Old Apr 14, 2017 | 09:29 AM
Aquadan005's Avatar
Aquadan005
OK, I must be missing something here. There just isn't enough room physically to get a torque wrench and socket on those bolts. I had to modify (grind down) a wrench just to get them off.
Old Apr 14, 2017 | 09:33 AM
Uncle Larry's Avatar
Uncle Larry
These can come in handy.
Old Apr 14, 2017 | 09:44 AM
Aquadan005's Avatar
Aquadan005
They look highly useful for just this situation. Do tell where you got them from. And thanks for sharing!!
Old Apr 14, 2017 | 09:46 AM
aquadave's Avatar
aquadave
switch the bolts to allen head. just try to use standard bolts on big bore jugs, the bolts won't even fit much less wrenches
Old Apr 14, 2017 | 03:53 PM
priceamp's Avatar
priceamp
Snap-on. Just remember to keep them at a 90 degree angle to the torque wrench handle. They're spendy, but a must have when torquing heads still in the frame.
Old Apr 14, 2017 | 05:10 PM
IKnowNot's Avatar
IKnowNot
An alternative to Snap-on:
http://www.mcmaster.com/#torque-wren...pters/=10mjemz
