ACRs/Install ? vs S&S EZ Start Cams
I'm doing some work to my 96" 2011 Road King. It's getting tired so I pulled the engine and will do a 103" or 107" bore. I have new ACR heads in hand but my engine did not come with ACRs. When I took the bike apart I found what appear to be ACR connections plugged into dummy plugs. My question is, if I install ACRs will I need an overlay harness? It doesn't appear that I will because the plugs are already there.
As a side note: I'm interested in opinions on S&S EZ Start cams vs ACRs. Thanks in advance.
PS
A friend came by as I was finishing up pulling the engine and asked what I was doing. I told him I was changing the oil and wanted to get it all out; his jaw dropped to the floor
PS
Campy Roadie (06-21-2017)
The 2011 wiring harness shows ACR wiring. You got the heads.. IIRC some 2011 models are 103s so they like used the same harness / ECU.. Sounds like you are there as far as ACRs go.. With ACRs you are tied to SnS cams..
I'm impressed if you pulled that motor by yourself..
I did do all the work by myself, without anyone here. I read the manual section a couple times, put the book down and got after it. In three hours it was on the floor (not broken or dinged up). I can't say I'd want to do it once a month, but it isn't a hateful job. I am a rider who's forced into doing mechanical work; some of which has been done at the side of the road, if you call the Dalton Highway a "highway".
Max Headflow (06-20-2017)
