Clearance high lift cams
03 up cases might be OK with that lift cam. Especially if running cam chains. Base circles can shrink. Gear drive cams can run larger base circles and need checking. Rocker boxes typically won't unless roller rockers are used. If larger valve springs are used, clearance between the springs and the covers need checking.
I will add to the good information, that best to check for upper spring collar, to rocker arm contact.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
they are just putting in new crank and doing heads, I'll be putting it back together, so I doubt they would have done the cam chest, and the rockers are in my garage.
