Think of a cam swap
Think of a cam swap
I have a 04 ultra with stage 1 hillside heads set at 9:8 compression , 98" jugs and the screaming eagle hydraulic cam plate with Andrews 26 cams. This set up made 95hp and 107 tq. Is there a cam that would give me more power. I want the torque to come on down low and pull hard through all rpm. Love this set up but the 26 seems to fall off around 4500 rpm.
You should talk to Scott. Absent his recommendation, cam selection is no limited by static compression and lift; I don't see many options without more compression and, perhaps, more lift as I don't know how the heads were set up. The first cam that comes to mind is the Andrews 48, assuming that the heads are setup to handle the higher lift.
I do think you would pick up a bit from the 48 both in peak numbers and the curve should move a bit to the left. Whether the marginal increase is worth it or not is a decision you would have to make.
a little off subject, but a question for those who have done a cam change.
is it possible to remove the lifters from the bottom when the cam assy is removed or do the lifter blocks have to come off to remove them?
only because I will soon be swapping my cams and lifters and need to know if will need new lifter block gaskets?
the factory service manual does not say yes or no regarding this.
a little off subject, but a question for those who have done a cam change. is it possible to remove the lifters from the bottom when the cam assy is removed or do the lifter blocks have to come off to remove them? only because I will soon be swapping my cams and lifters and need to know if will need new lifter block gaskets? the factory service manual does not say yes or no regarding this.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
I made 104 hp and 112 ft lb of torque with a set of RS .557 cams using a 44mm CV carb in my 98" there is absolutely no reason for a person to use a cam that has .620 lift in a 98" engine. Can you say, "over cammed"? Put a 1.90 intake and a 1.63 exhaust in the heads and put a good tune it.
