TC head cc's
actully ment MERRY CHRISMAS to you too,but your more than welcome to stop by tuesday
As djl and kirby stated, Get them cc'd have heard them get to 89 cc as well... 4 cc can make a lot of difference when it comes to cam selection... A cam that performs very well at 10:1 static compression will not perform as well at 9.6:1. 4 cc can make that much difference cause now your looking at a ccp difference of 10 psi. Take the Andrews 57 cam for example @10.06:1 static your dynamic comp would be 9.35:1 w/194 psi ccp. @ 9.69:1 with an 89 cc chamber your dynamic comp would be 9.0:1 w/185 psi ccp which will make the Andrews 57 cam soft on bottom....
Mind you these calculations were done @sea level..
Cleaned, prepped, and cc'd then you'll know, if staying with the untouched cylinder head.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
tgaetto
12-28-2006 01:58 AM
