Sputter
Old Dec 27, 2017 | 11:35 PM
HOGILAC's Avatar
HOGILAC
Default Sputter
I have an 03 Electra Glide.., when riding it spitters sometime and the check engine light comes on and then goes out after a few. I changed the fuel filter and still does it. Seems like less often but not sure what to check next. Should I check the plugs..., current plugs and wires were changed in the last year. I would appreciate and input
Old Dec 28, 2017 | 11:44 AM
djl's Avatar
djl
Carbed or EFI?
Old Dec 28, 2017 | 11:50 AM
LazySundays's Avatar
LazySundays
Check the wires to the front injector connector. They break inside the insulation. They may appear a bit narrower. Try to push and pull on the wires with the bike running on the side stand and see if it misses.
Your symptom is identical to how mine started.
You can also Google how to pull codes without a scan tool to see what codes are in memory.
Old Dec 28, 2017 | 12:38 PM
hrdtail78's Avatar
hrdtail78
A check engine light that comes on and then goes off, or stays on after starting and then goes off is a sign of a historic code. In your case I think it means it is an intermittent problem, but a code should be stored.
IDK if a historic code pops up in the speedo or if they are only active codes. Most flash base tuners and devices like Twin scan have the ability to pull active and historic codes.
Edited to add. Flash base tuners that are locked to another bike will still work for this. So, the question is what kind of tuner do you or your buddies have?
Old Dec 28, 2017 | 05:42 PM
HOGILAC's Avatar
HOGILAC
[QUOTE=djl;16946689]Carbed or EFI?
Old Dec 28, 2017 | 05:43 PM
HOGILAC's Avatar
HOGILAC
Originally Posted by djl
Carbed or EFI?
[QUOTE=HOGILAC;16947476]
Carbed or EFI?
efi
Old Dec 28, 2017 | 05:44 PM
HOGILAC's Avatar
HOGILAC
Goes off periodically when riding
Old Dec 28, 2017 | 05:46 PM
HOGILAC's Avatar
HOGILAC
No codes was in the memory.., I watched a YouTube video and checked the codes. They were all clr
Old Dec 29, 2017 | 06:40 AM
Fat11Lo's Avatar
Fat11Lo
Was the check engine light on before you checked codes? You may have to catch it while it's acting up, as Hardtiail has said not sure if flashing will display inactive codes. My instinct tells me you have an intermittent electrical issue that you may need better diagnostic capabilities than reading codes through speedo. As has already been suggested you may want to have the bike running and just go through and wiggle the wires and connections that you can reach and see if you can get it to happen, then you will know where to start looking. As always with any electrical issue check all of your grounds to make sure they are clean and tight. Good luck!
Old Dec 29, 2017 | 11:16 AM
djl's Avatar
djl
efi
Clean the IAC port; check YouTube for a video.
sjones73
Apr 6, 2019 05:18 PM
tripacer1
Aug 31, 2012 08:32 AM
Samber79
Nov 4, 2009 04:46 PM
dgretz
Sep 1, 2009 02:39 PM
smokeybud
May 26, 2008 10:13 AM
