Codes
Old Aug 30, 2012 | 10:24 PM
tripacer1's Avatar
tripacer1
6th Gear
Question Codes
need some one to give a little more information on 2 codes
P1357 Ign coil intermittent Secondary to me this means that the high tension side Plugs , Plug wires or the H T side of the coil is going south
P1651 Check engine light open / Low i dont have a Clue and did not get a real good answer from the dealer that read the codes
these were "Historical Codes" not sure what that is all about either
something caused these but dont know when
The check engine light would come on when you started but then go off shortly after starting
Im used to Cars if it drops a code it turns on the light and the only way to shut off light is to read code and manually Clear it
why would a engine drop a code and not turn the light on all the time ???
Thanks for your help
Old Aug 31, 2012 | 08:18 AM
smithbrl's Avatar
smithbrl
The P1357 could be a loose spark plug wire that tightened up and no longer causing a problem. I think it's a reminder to maybe look into the situation even though it's not "acting up" now.
Don't know about the other code.
Old Aug 31, 2012 | 08:32 AM
HDRoadking_nc's Avatar
HDRoadking_nc
https://www.hdforums.com/forum/elect...tic-codes.html
skizman
Jun 29, 2017 02:16 PM
fulldraw00
May 31, 2010 11:27 AM
Rubber Slinger
Apr 2, 2010 09:17 AM
SE120RG
Jul 20, 2009 08:00 AM
smokeybud
May 26, 2008 10:13 AM
