Fouled Plugs..barely runs..02 Road King
Started to run real bad, now barely runs. Spits..pauses..runs..spits. Both plugs are all black. Battery terminals clean and tight. No codes showing up. The word "diag" never comes up when I first start code check. It starts with codes 1-10 all showing clear, then goes to PPU, then to 82,000 number and back to the 10 codes. All lights work, no check engine light on. Battery is strong.
Just sounds like either fuel or electrics keep shutting on and off.
Someone mentioned maybe the MAP Sensor?
Be nice if it showed a code.
Bike has no add ons.
Your input is certainly appreciated!!!!!!!
Hey Skiz,
Pardon me if you already are aware of this. Turn on the ignition. Wait for the odo to light up. Turn the off/run switch to run position. The red check engine light will light up and stay lit for about 10 seconds or so. Keep watching the light. count to 10 and see if it comes back on. If you had a bad MAP you should throw a code.
When you say no codes, after you jump the data plug and go through the routine you are watching the check engine light, correct?
A great thread with explicit instructions can be found here
https://www.hdforums.com/forum/touri...dtc-codes.html
Hope you get this figured out.
Garrman
Garrman
The primary side should be in the 3-5 ohm range. The secondary side should be greater than 10K ohms.
Are you getting 12 volts power in?
You mentioned your plugs are fouled. Are they black?
Black and wet would suggest oil fouling.
Black with fluffy or sooty deposits indicate a rich condition.
Any signs of arcing on the plug wires?
Any buddies close by that might loan you a coil for troubleshooting?
Have you done a compression check to rule that out?
Just some things to check. While coils do go bad it is somewhat rare.
Garrman
Garrman
HogMan
10-09-2008 10:00 AM
