.107" crank endplay
Is the side to side play of flywheels with comp bolted up or removed? If it is removed. The comp being bolted up is the what locks the flywheel to left case on roller bearings.
How is your Oil pump and cam support plate. I have to assume with .107 runout. They are trashed.
How does this happen? My best guess is always engine breaking more than just pure power twisting a crank but your guess is as good as anybody's.
Comp sprocket assembly needs to be in place and torqued, then end play can be witnessed.
If in the loose state, the flywheel assembly will move side to side.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Oops! My bad!
hrdtai78 and Scott's follow up bear out my question as to how the OP determined crank end play is .107" which seems an awful lot. I am betting that the measurement is not the correct measurement the OP should be looking at but wanted to be sure.
I measured the end play before I disassembled the case with the stock bearings. When I grabbed the crank shaft I could see the flywheels visibly moving so using a digital caliper I measured each extreme of movement and did the math.
If this is the case, I wish the service manual would have noted it that way. I'll bolt the case back together tomorrow and put the compensator on and try again.
Run out measured with crank in case before disassembly was .004" at the end of the pinion shaft.
