Thoughts on a 98" Big Bore build with 585 Cams?
I’ve had really good luck with Aaron and Dan at hammer and they are close to you. Tell him what you have and how you plan to use it and he can match the heads to what you need, he talked me into a cheaper build than I had originally wanted because of how I wanted to use the back. It ran very well and was what I wanted. I like the way he works with you on the build sheet as well, you get to see and he answers your questions and changes what needs to be until your both happy with the options. If I was in Idaho that’s who I’d use.
I'm reposting my previous reply to your post because I figured out how to "quote" the message I'm responding to..... F#$#%^&N forum newbies!!!!!
BigBoyz (http://www.bigboyzheadporting.com)
Hammer Performance (http://www.hammerperf.com/tcporting.shtml)
NRHS V-Twin Performance (http://nrhsperformance.com/cncporting.shtml)
or possibly S&S Cycle (https://www.sscycle.com/go-fast-show...ystem-upgrades).
I've looked around at a few local shops, but I'm still leaning with the porters above.
Just make sure you get your compression right for those cams. I have a 95" bog bore on my '02 FLTR with gear drive S&S 585's with some headwork. The power comes on around 3100-3200rpm and from there it is a rocketship....Getting that big heavy bike off the line with those cams in a smaller displacement is a different story.
Thats great to hear.... I love those numbers. What RPM range does the cam kick in at? Im not a phsyco rider, but I do like to jump on it once in a while, so the useable RPM range for the way I usually ride would be roughly 1800-4500, give or take. Just wondering if I selected the wrong cam to get that range.
So, my Dyna is probably on the heavier side for a Dyna because the accessories add weight; hard bags and cargo, fairing with stereo, floor boards and highway bar (see pic in one of my previous posts in this thread). I would prefer the cam to kick in at a lower RPM than the 3100-3200 you mentioned. Im wondering if the additional 3CCs (95" to 98") will make any difference? Also, I heard of folks add some type of cam offset to shift the timing.... not sure though.
Phinatic62 (01-15-2018)
Thanks... great information. I will do some research on Hillside regarding the head work. As far as the carb goes, I had one person tell me that I may need to go to a 45 so that the carb doesn't hold me back from getting the most out of the build.... I guess I'll find out when it gets on the Dyno. Also, I noticed from your profile that it appears our Dynas are pretty similar; I have a Dead Center fairing as well.... attached pic for your viewing pleasure.
551 - This is a bolt-in cam set designed for stock or mildly modified touring bikes. I don't have a touring bike, so I'm not sure how much of a difference that would make.
570 - This cam will provide a nice power increase across the entire power band. 3200-5700 rpm. The cam doesnt kick in until 3200 RPMs.
Going to do some on some Andrews and Woods cams now. Thanks.
So, I checked out the descriptions on the S&S web page and here is what they had to say, and my comments:
But if you already have the 585 then Aaron can give you the best advice. While your looking around check out wfo Larry as well he does good work.
