113 S&S 631 cam 11:1
Old 01-20-2018, 02:55 PM
brad75raiders's Avatar
brad75raiders
brad75raiders is offline
Default 113 S&S 631 cam 11:1
Anyone here run this combo? I have this in my FXR and the friken bike screams. I was thinking of another cam to bring the TQ on sooner. its a revver like 6+ rpm 3500 up its stupid.{ put out 127/131 hp tq. back when it was built 1999.} what cam are you guys running on yr evo big blocks? would a woods 9B or 9f work with 11:1 or other....
Old 01-20-2018, 03:10 PM
marcodarq's Avatar
marcodarq
marcodarq is offline
the 600 cam worked pretty well in those engines and came on a little sooner, but you might lose some on top.
m
Old 01-20-2018, 03:48 PM
brad75raiders
does the 600 play well with 11:1 compression
Old 01-20-2018, 06:13 PM
ntraindavefl's Avatar
ntraindavefl
ntraindavefl is offline
The 9b would strike off bottom the best at 11:1
But to get ccp up around 205 and stupid fun quick hard hitting tq, the wood 8.
Old 01-20-2018, 08:28 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,818 Likes on 3,320 Posts
Agree on the 8. Hits stupid hard at 3500.... And will carry past 6k no problem...
brad75raiders (02-03-2018)
Old 01-20-2018, 09:10 PM
ntraindavefl
And in a 113/117 will rip from 2700rpm w the right pipe
Old 01-21-2018, 07:04 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,259 Likes on 3,629 Posts
SnS 113 evo. CR set at about 10.8 with a 640 cam that was advanced 3 degrees.. Super G bored to 1.85 with one T jet.. dyna 2000I curve 4 with timing mark left side of window. Home made staggered duals. 4th gear run.. 11.29@121.8 in bobber.
Old 01-22-2018, 05:56 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
I'd lean in the direction of a Wood 9F, at 11.0-11.2.
Smash big torque early and carry it.
113" on our site........130/140.....client would drive the FXR to the track....blast out 10 sec pulls, and drive it home, beating trailered bikes...lol.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 01-30-2018, 08:47 PM
brad75raiders
Scott
Scott
The 631 has a 631 lift the 9f looks to be 650. I wonder if I have enough room?
Old 02-01-2018, 03:56 AM
Hillsidecycle.com
Sponsor
If those springs are 20 years old, I'd put an eyeball on them anyway.
You'll have plenty of valve/valve, piston/valve, .631 vs Wood 9F.
Upper collar to seal, and coil bind, might, be a concern.
Best to check it out.
Scott
Quick Reply: 113 S&S 631 cam 11:1
