S&S 110 Sidewinder kit with SE heads
Received 2,191 Likes
i used the kit with s&s heads. No reason why they wouldn't work with se heads. They are meant to function like stock hd equipment.
just check your clearances as you would in any other case.
instead asking randoms, why not call/contact s&s directly?
(608) 627-1497
https://www.sscycle.com/contact
(608) 627-1497
thats why you check the clearance. The 103 heads will work just fine. Have someone slap the acrs in if you dont want yo buy or make a tool.
twism_23
Exhaust System Topics
11-16-2012 03:07 PM
