TC88 Lifter Choice, Did I choose Wrong....
Last spring I bought a 2003 FLHCI w/43,000 mikes on her. I was told that the Cam Chain tensioner's were not done so I deiced to do the Andrews TC96 swap. I used new Screaming Eagle adjustable push rods and Lifters. After about 1500 miles the engine seemed to get very noisy and we suspect that it may be the lifters. I am going to install ROCKOUT's before the riding season here in New England and I'm wondering if I should dump the SE Lifters as well. Thanks in advance for your time
ROCKOUT Rocker Products (04-14-2018)
BadDadFLTR (04-13-2018)
Ok what S&S lifters do I use, seems to be on confusion as to where the entry ones are being made...
u want s&s standards
they are about 135 bucks u don't want the ones with travel limiters. they have a spacer at the bottom that kind of turns it into a solid lifter . think u would get a limited amount of oil going to the top end with those , harely says use 2.5 turns. most of the engine builders recommend .140 which is 3 .5 turns after rod starts to load up when lash is out. be careful with those se lock nuts they split real easy I got rid of mine after one cracked, I used a 5/16 nut retapped to 3/8-24 thread, verify thread picth on your rods before trying to run a diff nut up it, a real 3/8 -24 nut may be pretty big to add to the weight of the rod. make sure u wait 20-30 after setting a rod that if spins indicating the lifter has bled down before u try and set the next lifter, if u try to rotate the motor over right away u could bend a valve. hope I have this pitch turn guide for se push rod correct. my set of se rods is 3/8-24 about 8 years old
turns trhd pitch amount extend
0.5 0.040 0.020
1 0.040 0.040
1.5 0.040 0.060
2 0.040 0.080
2.5 0.040 0.100
3 0.040 0.120
3.5 0.040 0.140
0.5 0.040 0.020
1 0.040 0.040
1.5 0.040 0.060
2 0.040 0.080
2.5 0.040 0.100
3 0.040 0.120
3.5 0.040 0.140
I like Larry’s lifters.... his website is http://www.larrysmotorcyclemachine.com/home.html
He’s usually in most of these forums as well was wfolarry
http://www.larrysmotorcyclemachine.com/lifters.html
They're what I used in my build--#2313. Nice and quiet once all of them properly pumped up.
