Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Looking to swap the cams in my wife's 07 Street Bob, and need suggestions. The build is
103"
Compression set at 10.7:1
Ported heads with 1.9 int
and 1.630 exh valves w/comp. releases
50mm tb with 5.3 injectors
D&D Fatcat pipe
Bike is currently running SE259e cams and dyno'd 116/118, but just doesn't pull as hard and isn't as quick as she would like. I like the Wood 999-6, but not sure if we would gain much without increasing compression.
Or should I keep the 259's, and go with different gearing?
Any thoughts? Thanks.
If you're already at 116/118 I would really wonder if the gains from a cam swap would be worthwhile?
The gearing swap sounds like a good path, I'm looking into it myself for my '15 Limited. Only thing is I kinda feel like I run out of 1st gear too soon already
All roads lead to a 124
__________________________________________________ ____ For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
