Lifter size question
Old 11-24-2018, 01:30 PM
LQQK_OUT's Avatar
LQQK_OUT
LQQK_OUT is offline
Received 1,565 Likes on 1,083 Posts
Default Lifter size question
If one replaces the stock HD lifter (ie HD# 18538-99C) with an aftermarket one (ie S&S Premium High Performance 330-0175 or High Performance 33-5350) can one still use their stock non-adjustable pushrods?
Old 11-24-2018, 01:48 PM
Kingglide549's Avatar
Kingglide549
Kingglide549 is offline
Yes, if all other things in there remain about the same height.
Nonadjustable are just a PIA .
LQQK_OUT (11-24-2018)
Old 11-24-2018, 03:32 PM
marcodarq's Avatar
marcodarq
marcodarq is offline
yes as long as you are using the stoc cam or a cam that has the same base circle spec as a stock cam, you can use the stock pushrods. just as a note, a lot of people go to adjustable pushrods so that they can do cam/lifter/oil pump stuff without the need to take apart the rocker boxes.
m
Teagan
Shovelhead
07-17-2018 02:14 AM
CR3999
2014-2023 Touring Models
02-23-2016 04:52 PM
fordhunt
EVO
05-14-2013 02:13 PM
troop
Exhaust System Topics
03-23-2010 08:13 AM
90evo
12-24-2009 01:56 PM
Quick Reply: Lifter size question
