Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I have a 2015 RGS with D&D Fat cat and SE Elite Breather, I have decided on CR570-2 cams, was thinking about the S&S lifters and quicky rods, but fuelmoto has kit, would I be better to get S&S or is there no real difference between the two
Did you get the cams installed. If so, how do you like them? I just picked up the same ones with S&S lifters. Looking at going with FM pushrods and cam install kit.
