Cam Chest Refresh
They also said that they don't make that one, so they had to go measure it by hand.
Doing some calculations:
The stock lifter oil hole (.100") has .007853 in^2 area
The Crane/LS1 lifters, at .080" or .070" per that picture above, have .005027 or .003848 respectively. (64% and 49% of the original areas respectively)
You have to think that the oil system in a twin cam runs at relatively low psi, 5-10 psi at idle. If you restrict the lifter oil hole by over half the area, the oil will find somewhere else to go, as the other holes the oil goes to in the engine haven't changed sizes. As seen in the S&S video, this could result in a lack of oil flowing to the rocker box/ no bueno.
I was considering saving the ~$50 by using the chevy lifters, but after crunching the numbers, I will buy the motorcycle lifters.
Not really. It's more of a heating function..
I took out at around 36k next to a fueling shoe that was in my bike for about 6500 miles. I wouldn't use fueling if they were free...needless to say they're not going back in my bike. I hope you have better luck with yours.
unfortunately replacing the cups is not a possiblilty with the "C" lifters that I had. totally different design internally. Here are some pics to hopefully clarify
First up is the Harley "C" lifter
[img]
[img]
Oil hole in the side of the "C" lifter. this measures about .072". this will be the bottleneck in the oil flow puzzle. IIRC, you cant flow more through the system than the smallest orifice
Top part of the plunger/pushrod cup. Oil hole here is .092" this rides directly above the lower cup in the main lifter body
Top view of the pushrod cup. oil hole is the much touted .100"
bottom of the pushrod cup. Note that the "metering disk" is swaged in, and solid. the only oil going through this is from the hole in the side.
lower plunger piece with pushrod cup just above it. this is how it sits in the lifter body
[img]
Axle is held in with a pair of tiny "C" clips and rotates freely in the lifter body. Think of a wristpin, and this is the same. Not the best I think
you can just barely see the rollers in this pic. If one goes to ****, they can easily just fall out. rollers are barely below the side of the body.
