Labor cost to install S&S 110” kit
Anyone install or have installed the S&S 110” kit on 96” engine? I’m trying to figure out what the job will cost for a good mechanic to do the install for me so I can guess how long it will be before I can afford to do it. I already expect the kit and other related parts needed will probably be around $3k but I have no idea what the labor charge would be. Thanks in advance for any helpful info.
TerryMcQ (02-14-2019)
djl, forgive my ignorance but I'm relatively new to all this. Are you referring to possibly having the heads machined or some other machining? I guess am trying to figure a base labor price if all goes according to plan and the contingency fund of course gets added when and if necessary. I have not had any major work done where I took my 2009 Low Rider to a mechanic. I bought it with a salvage title and put "new" used tins on and lights, Rinehart exhaust, Mustang seat, forward controls, K&N air filter, throttle cables, etc. I did all the miscellaneous stuff necessary to plate and insure it. Now that I want to get more power than what I guess is referred to as Stage 1, I am hoping to get an idea of what I should expect mechanics to charge to install this or similar kit. I know what they charge on average per hour but I don't know how much time to expect this build to take. If I had to guess, I would think a good mechanic could do it in a 8 hour day but I could be full of ****. I was an auto mechanic back in the 70s and we rebuilt engines in a couple days but I have no idea how the tasks might compare beside guessing.
Considering the work you have done on the bike so far, why not take on the project yourself? Not to over simplify but it's just following instructions and turning wrenches, the magic is in the tuning. You should consider contacting Scott/Hillside Cycles (yes, NY) or Kirby/Veetwin for a 107" kit which could be had for less than the 110 kit and would perform very well. It would be worth a couple of phone calls before pulling the trigger.
djl, I forgot to say I also got the Vance & Hines Fuelpak FP3 when I installed the Rinehart 2-into-1 pipes, made a nice immediately noticeable difference. I should have realized that if I put that kit on, it's best to do the heads too. What about the transmission? You say to get the 107" kit but does that do all necessary or would I still also need to upgrade or at least refresh the heads? Am I right in thinking the best thing to do is get whatever kit I decide on, do the heads, and get the better throttle body? As for doing it myself, I've thought about it and I'm not completely decided yet but I am a bit burned out from a lot of years of hard labor and the knees, hands, shoulders, back, etc. rebel too easily. That's why I need a rough idea of what it would cost to have an expert do the whole job. It would be great if I could have Hillside or Veetwin do the job but I probably need to find someone in Indianapolis area where I live. Just not sure how to know who is good unless someone on here can recommend an expert in the Indy area. I know some companies names but I don't KNOW them. Have you heard of anyone in the Indy area?
