engine spins but doesnt crank
I have a 95 Harley Dyna super glide and the other day while riding my bike bogged down when I tried to speed up to get on the highway. When I pulled over I could hear a sound coming from the primary cover. I was able to get the bike almost home when it lost all power to the motor and I pretty much had to coast the bike down a hill to get to where I could have a buddy pick up my bike. Since getting the bike home I have been trying to see what could be the issue but to no luck so far. When I pulled the cover everything looks fine nothing torn or broken. No broken metal, everything still looks really good. I checked the starter and it catches and turns over but still does not start the bike when I try to start the bike now it sounds really fast with a click sound that's coming from the starter/ primary area. I'm not trying to spend a crap ton of money on this issue even though it looks like I might have to. Does anyone have an idea of what may be the issue? I have a video but it's not loading on the forum.
Oscar Curry (03-05-2019)
If the starter does indeed spin the motor over, do as TwiZted says. Need to do a compression test. 140+ psi in both cylinders for a stock motor is good... If that tests good then start with the ignition. The cam position sensors have been known to fail..(brown Goo).... Do you have a Factory Service Manual?
Received 5,433 Likes
The following 2 users liked this post by RANGER73:
Fat11Lo (03-11-2019),
Max Headflow (03-09-2019)
Do the simple **** first save yourself some head scratching and hand wringing.
