A wee bit to much torque...
Old Mar 14, 2019 | 07:47 PM
NIGHTTRAIN2007's Avatar
NIGHTTRAIN2007
Default A wee bit to much torque...
Can anyone give some insight to the 6 coil spring pressure plate type conpaired to the SE diaphragm type clutch spring. Did my 107 build and stock clutch can't handle torque any longer. The set up I did is great but I am eager to hit it hard but slips a wee bit at 1/3 throttle and do not want to trash new friction plates.
Thanks in advance.
Old Mar 14, 2019 | 09:28 PM
langwilliams's Avatar
langwilliams
I have no experience to offer but I'm changing cams soon an an if I get slippage I'm considering this one. it's a complete kit not adding springs it replaces it. you might have to consider taking what you got out an selling it for a beefier set up
https://rekluse.com/product/torq-drive-clutch-hd/
Old Mar 15, 2019 | 01:35 AM
NIGHTTRAIN2007
Have already upgraded the friction disks and metal plates...
But thank you for the info.
Old Mar 15, 2019 | 02:41 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
AIM 95LT lock-up hat.
We've use/stock those for almost 2 decades now.
Will NOT slip.
Scott
Old Mar 15, 2019 | 10:24 AM
hrdtail78's Avatar
hrdtail78
Got a sheet? Got tq numbers at rpm's? Hat's work great above a certain RPM but do little down low. I have had great luch with Energy Ones BTX systems. They have an extra plate and heavier spring.
IME the biggest difference in springs is the feeling. A diaphragm spring gives you a rock over effect like a compound bow and a wound spring clutch is more of a linear pull. Either will hold gobs of tq down low if the spring or springs are heavy enough.
Old Mar 15, 2019 | 01:53 PM
aaa1988's Avatar
aaa1988
Will NOT slip.
Scott
Old Mar 15, 2019 | 05:42 PM
cdonis's Avatar
cdonis
Barnett Scorpion and basket
Old Mar 15, 2019 | 07:17 PM
GaryLC's Avatar
GaryLC
1 more vote for the Barnett Scorpion and basket.
Old Mar 15, 2019 | 11:22 PM
HD Bobber's Avatar
HD Bobber
another vote for the Scorpion...had it on my previous build and it was an awesome setup!
Old Mar 16, 2019 | 08:49 AM
Fat11Lo's Avatar
Fat11Lo
Scorpion lock up and billet basket is what I used, didn't want to have to buy another clutch should I ever decide to go bigger
