88ci Cam Chain Tensioner 21k Questions
Just purchased a 2003 super glide with 21k miles all original. Located Gettsburg Pennsylvania area. Nothing has been done with the tensioners yet and would like to ponder the knowledge of the members here. I will be using a shop to perform any work performed, and was wondering if there are any recommended shops in my area. Want this to be done correct and don't want to risk my ability.
Either I will be just replacing the cam shoes for now and was wondering average cost for a shop to put in the cyco shoes (depending on the cost of the following option).
Or my preferred option of going hydraulic tensioners, pistons cams to benefit for everyday usage etc, other parts needed and labor. With this option I was wondering what the best brand kits or parts and the favorite cams of the members for streetability and 2up riding. Pricing?
Most of the posts I've seen searching are a couple years old and didn't know what kind of options I have here in 2019. Thanks! Would like to get a fix as soon as possible as I'm worried the original shoes will fail from the horror stories I've seen
No need to spend the money on hydraulic tensioners and roller chains; save the $$ for cams and tune. Replace the OEM tensioners with a set of CYCO tensioners and replace the inner and outer cam bearings along with the cam install. '03 model year lifters were "B" type and if not noisy, no need to replace at 21K miles IMHO. The $$ saved by passing on hydro tensioners and roller chains would be better spent on a Power Vision license and a dyno tune, if a local tuner is sellling licences; most do these days and will provide the customer with the tune on a thumb drive. Andrews 21 or S&S 509 cams would be a good choice for an TC88.
This assumes that being a 2003, the previous owner has paid the Harley "tax" for the Stage I upgrade of intake and exhaust. If this has not been done consider backing up and getting this done first or, if funds allow, do it all at once.
The following 2 users liked this post by djl:
duglaura&flhti (06-21-2019),
Mattbastard (05-28-2019)
More than capable 😂. Either way at 17 years old going to do something in the near future. Just looking for opinions on the best routes to take. Harley noob here. Just started riding not too long ago on a 1999 sportster I have.
Thanks djl, called two local shops a couple hours ago asking for an estimate on bearings, cyco shoes, cam, a/c and rejet (dynas are still carb 2003). No reply from either today. Bike has Vance & Hines pipes already only thing aftermarket on it. Looks like this is the best route to take
I suspect you are looking at $1500 plus for the work you outlined above depending on the shop labor rate.
Go with Harley's shoes and gaskets. They will be there for another 50k 15 + years. Forget any upgrade. Hydraulic is not an upgrade. Since your inner cam sprocket is part of cam for the link chain, it will remain link. So only outer will get roller chain. It's the chain, not the hydraulic that prevents wear.
With a roller chain, once the outer links groove in, chain rolls and wear stops.
Shoes and a few gaskets, Check oil pressure with and external gage screwed into pressure fitting. But still inspection oil pump for wear, replace the o-ring in it. Also inspect the inner cam needle bearings.
DO NOT use HD shoes,at the very least go with CYCO shoes,OEM orange pads start doing damage from mile one.best is a gear drive if your run out will allow it
The following 3 users liked this post by prodrag1320:
This. Don't let anyone talk you into upgrading to hydraulic, it's not necessary. Sure the shoes are basically permanent with hydraulic but the spring loaded ones go 30K-50K anyway, sometimes longer if you take a few measures towards longevity (Cyco shoes, sanding/polishing the chain, dino oils).
So Dino oils help? Original owner had service records and always ran conventional oil in the motor. I just did an oil change and used Mobil 1 vtwin synthetic though. Rotella t4 15w40 in primary and mob1 75w90 in tranny
