engine problem
Old Jun 22, 2019 | 07:23 PM
Lavaughn Keener's Avatar
Lavaughn Keener
Stage II
Default engine problem
I have an 07 ultra classic with a 110 screaming eagle i lost oil pressure and it started to rattle so hauled it home took the oil pump out looks brand new its a fueling brand and it is not binding up either what is my issue please help
Old Jun 22, 2019 | 09:03 PM
Max Headflow's Avatar
Max Headflow
Pressure relief valve in the cam plate is probably stuck.
Old Jun 22, 2019 | 09:24 PM
Lavaughn Keener
Stage II
Ok thank you I'll check it
Old Jun 24, 2019 | 05:53 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
The root issue with those 110" engines seems to stem from the colossal valve spring pressures generated by the Comp Cams springs that HD used in those heads.
They harm the lifter axles/rollers, and in turn, wipe out the pump, and plate, and can destroy the inner cam bearings
That said, do not disregard any odd noises that may crop up.
Scott
cthagreekgod
Engine Mechanical Topics
Jul 2, 2019 07:45 AM
GibsonSG
Feb 22, 2017 11:58 AM
Biker Boy 53
Oil Archive (no new posts)
Sep 22, 2015 03:00 AM
BigMikeHD
Exhaust System Topics
22
Oct 15, 2013 03:02 PM
ron bayless
Jun 20, 2009 03:49 AM
