How far can you push a 96" TC Head
Received 70,432 Likes
This will be more of a hot rod build so I'm looking to maximize hp.
Ill be on the lookout for some 110 heads or MVAs.
Thanks
I built mine to be around this numbers, didn't put it yet on a dyno but im pretty sure that is closer to 140 than to 150, I would say around 135hp based on my butt dyno, I have a set of 110 heads @ bit over 300 and i'm not sure if they're the bottleneck, or maybe the 58mm HPI unit.
What would the minimum CFM for a 150hp 124" be?
I'm running the FM e-series for dynas, I know for a fact that it does support 150 hp as FM themselves run one on a 117 and Jamie told me that he is using it on another dyna pushing 160 without issues, I was between the e-series and the boarzilla and ended with the FM mainly due to being quieter.
With purpose built G.W. heads and a wood 68 sure it should go 150. But if a stock head casting worked for typical street use and a more street friendly typical big motor cam, 150+ hp unlikely.
You're right, they had GW heads and probably 12:1 or more comp with those cams, still it was a 117, a 124 should reach the 150s easier, I have a feeling that something is holding me back because the engine wants more fuel in low-mid range but wants less at upper rpms, Im running the woods 9B set at 11.2 comp, my heads are 110 castings ported to a bit over 300cfm, that's why I asked since Kirby said that heads pushing 300cfms won't get you past a mild 124 (I consider mild around 135-140 hp)
I like to see my 110 heads in the 325+ area,really hard to put a number on what 300cfm heads would do on a 124" without knowing the rest of the build,but even on a very aggressive build I wouldn't expect more than 130,maybe 135
