How far can you push a 96" TC Head
Old Jun 25, 2019 | 08:14 AM
Big_O's Avatar
Big_O
Default How far can you push a 96" TC Head
What is the most cfm you can squeeze out of a 96" TC Head casting?
For a 150+hp 124" build, are you better off spending some more coin on a set of 110 heads and having them worked over?
Thanks
Old Jun 26, 2019 | 06:00 AM
prodrag1320's Avatar
prodrag1320
Thanks
we use 110 heads on most our 124" builds,yeilding in the 325 @ 28" area after porting,getting this CFM out of stock castings wouldnt be cost effective.
Old Jun 26, 2019 | 06:51 AM
Mattbastard's Avatar
Mattbastard
Aside from compression releases, what actually changes in the head casting between, 88", 96", 103", and the 110"?
Old Jun 26, 2019 | 07:10 AM
Big_O's Avatar
Big_O
I believe the 110 heads have a larger chamber volume requiring domed pistons to bring compression up.
Just a guess, but maybe the larger chamber volume allows for more surface area which allows for larger valves?
Old Jun 26, 2019 | 10:30 AM
djl's Avatar
djl
Minor differences in the TC88 heads; biggest change was in '05 beehive springs and 7mm valve stems and new guide seals.
'06 heads had larger exhaust port due to the lowered chamber floor and they flowed better; 96 and 103 heads are the same.
110 heads, Big_O points out had larger 95cc chambers and chambers were the not the "bathtub" shape as the TC88/96/103 heads; 110 heads also had larger valves.
This is generally applicable to the OEM heads; there are the other performance configurations like the early HTCC, and SE Performance heads, MVA, CNC ported, Hurricane, etc. that had their own unique differences.
Old Jun 26, 2019 | 01:40 PM
Sisu's Avatar
Sisu
Check out what Zippers has to offer.
Old Jun 27, 2019 | 06:10 AM
prodrag1320
besides the .310" to 7mm valves sizes,slightly different intake & bigger ex port,the 88 & 96/103 heads are pretty much the same.110 heads are vastly different as far as ports,combustion chambers & valve sizes go
Old Jun 27, 2019 | 06:19 AM
Mattbastard
Thanks Kirby, that's kinda what I figured. My dad made an assumption that a set of 103" heads on my 88" TC would give me vast power gains, which made me wonder where he's coming from. He just assumed that the increase in displacement brought with it some better flowing heads.
Old Jun 27, 2019 | 07:25 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
We see 300 cfm @ 28" from our Stage IV, 2" valve head.
Scott
Old Jun 27, 2019 | 07:31 AM
Big_O's Avatar
Big_O
Scott
What kind of hp does that get you with say, a Wood 9f or maybe even a TW-68 with a good TB and pipe on a 124?
Thanks Scott!
