T/C 88 OEM Cylinder Max Bore
Hillsidecycle.com (11-01-2019)
An overbore of .1875 or 3/16”
plenty of room.
OP asked the biggest in a stock cylinder which is 3.938" for a displacement of 98" with the stock 4.00" stroke. S&S and HD sell 4.00" cylinders to make a square 100" but it is much cheaper to bore stock seasoned cylinders than pay for a new set. CP and Wiseco make pistons for the 3.938" bore. If one is already buying pistons and paying for a bore job why not get the extra 3ci for the same money? Free displacement is good!
just tossing in an option, no harm in choices
Thanks for the replies. I plan to open up the cam chest and check crank run out. I'm pretty sure I am going to find that I need to split the cases and true ,or replace the crank. I'm looking at about 90k miles right now and she's still strong but a little long in the tooth.
If I decide to pull the motor and split the cases most likely I won't go back stock, I'll spend the money on a new crank with a 4 5/8" stroke, chain drive cam etc. Once the bottom end is fresh again I can worry about the top end.
I can get the stock cylinders bored for nearly nothing and I can port and polish the heads myself. I'll probably do this much even if the crank checks out and I leave it stock.
