To pull Rockers or Not (Cam upgrade)
Hey yall.
I am in the process of sourcing all the extra parts to go along with my cam upgrade. I have a set of @fuelmoto adjustable pushrods and SE255 cams that I am going to be installing. The question is, do I just go ahead and pull the rockers and do the Rockout inserts and install the pushrods that way or do I leave the top end alone? I can do either and just wanting to see if anyone else has had that debate?
ROCKOUT Rocker Products (12-23-2020)
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
major105bc (12-24-2020)
The following 2 users liked this post by bad tappets:
major105bc (12-27-2020),
ROCKOUT Rocker Products (12-24-2020)
He didn't. Just figured this would be a very beneficial reason to pull rockers and then go one step further.
ROCKOUT Rocker Products (12-26-2020)
Well....just an update. I did end up ordering a top end gasket set and @ROCKOUT Rocker Products kit. I am going to do the full change and keep the stock pushrods. I am now trying to find an inner cam bearing tool to rent/borrow. I can only see me using it once and the cost doesn't seem to justify buying it.
ROCKOUT Rocker Products (01-04-2021)
