Center crankcase bolt between the cylinders on real big cylinder builds?? Twin Cam
What are you guys doing on the real big stuff for the top center case bolt? The one that gets ate into when boring the cases real big for like 4.250 or larger bores ? In hindsight, I suppose I could have notched or relieved the spigot (sleeve portion below the aluminum jug) even more than it already is. Don’t really like that thought. I’ve seen in s&s instruction for their 124 kits that they include a special bolt but I haven’t seen one. I took a 1/4-20 bolt that was long enough to go all the way thru the cases and use a nut on the other side. Turned it down in the center a little at a time and went back and forth to the engine then back to the lathe till I got it to clear. Wasn’t anything left of it. I did machine away the case where it got super thin and also went ahead and drill out what was left of the threads and spot faced a pad for the new nut on the other side of case
We remove the v-shaped tang and machine it.
Then we use use special extended-length tooling to establish a machined surface for the sealing washer.
Used to "neck" down the center bolts in one of our lathes when doing Axtell 3.812" bores on Shovels and Evo's.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Locomotion (03-31-2021)
tkuligowski
General Topics/Tech Tips
02-23-2017 01:57 PM
