This ever happen to you?
Old Mar 30, 2021 | 11:22 PM
sharps45100's Avatar
sharps45100
Default This ever happen to you?
I was adjusting my pushrods and was on my last one. Went the correct amount of turns to get to .140 and was tightening the jam nut and it cracked! Now I need to know where do I get a jam nut for screaming eagle adjustable push rods with 24tpi? Can't believe this happened.
Old Mar 30, 2021 | 11:51 PM
JustDave13's Avatar
JustDave13
I've heard of this but never had it happen, if it did happen too me I'd take the push rod out and pick up a replacement lock nut at a local hardware store.
Old Mar 31, 2021 | 06:33 AM
sharps45100
Didn't know if just using a nut from hardware store would be sufficient or is this a special made nut?
Old Mar 31, 2021 | 07:18 AM
JustDave13's Avatar
JustDave13
The lock nut on my adjustables look like a normal nut. Take the push rod with you and use it to match up a replacement.
Old Mar 31, 2021 | 07:26 AM
MACDBF's Avatar
MACDBF
Yes I had a buddy snap one off last summer, first time seeing that too. But we got a nut at the hardware store to match. His hasn't moved since, you'll be fine.
Mac
Old Mar 31, 2021 | 08:28 AM
sharps45100
Ok thank you all for the info! After work today I'll stop at hardware store and pick up a nut so I can get bike on the road!
Old Mar 31, 2021 | 10:56 AM
470004's Avatar
470004
I had a set of the SE Premium Tapered Adjustable Pushrods, part #18404-08 and had the same problems with the jam nut. I replaced the with the same size jam nut (3/8-24 with 5/16 hex size) from Smith Brothers Pushrods; https://www.pushrods.net/. There were a few old threats on this forum about the SE pushrod jam nut cracking.
sixgun95
General Topics/Tech Tips
11
Oct 21, 2020 07:00 PM
470004
Mar 19, 2019 06:44 AM
dubepj
EVO
13
Jan 29, 2019 03:56 PM
choptop
Jul 10, 2008 08:28 PM
notarheli
Exhaust System Topics
Jun 8, 2008 12:58 PM
