Fueling cam plate
Old Jul 18, 2022 | 10:25 AM
gooberhd1's Avatar
gooberhd1
Default Fueling cam plate
I was wondering if fueling cam plate with stock pump is worth the money
Old Jul 18, 2022 | 10:44 AM
Flo-rida's Avatar
Flo-rida
What year and bike are you looking to put one on?
Old Jul 18, 2022 | 10:57 AM
gooberhd1's Avatar
gooberhd1
20 triglide. Sorry forgot that
Old Jul 18, 2022 | 10:58 AM
gooberhd1's Avatar
gooberhd1
trike turns lot of rpm at 70 and ride in Texas heat!!
Old Jul 18, 2022 | 11:02 AM
eighteight's Avatar
eighteight
Can`t see how a fancy cam plate will change the revs or the temperature
Old Jul 18, 2022 | 11:17 AM
djl's Avatar
djl
No. If concerned about oil temps, install an oil cooler. I live/ride in south Texas and ran two oil coolers on my '02 FLHT with built all bore 107" motor; kept oil max oil temps at 220*-225* in 100* temps. The exception was getting stuck in "parade" type traffic in which case, I split lanes or hit the shoulder.
Old Jul 18, 2022 | 11:28 AM
gooberhd1's Avatar
gooberhd1
I was wondering if the plate pumped more oil or did anything different than stock plate. Thanks for input
Old Jul 19, 2022 | 07:27 AM
ThePaintPirate's Avatar
ThePaintPirate
The OE+ plate is just an original replacement while they say the HF plate moves a little more oil. The OEM plate is perfectly fine unless you're building a high HP race engine. I wouldn't waste money on it.
Old Jul 19, 2022 | 08:48 AM
Max Headflow's Avatar
Max Headflow
I agree with dlj, add coolers but also add head fans. The fancy plate might claim to have more flow but flow in a TC or M8 is really determined by the pump and where the oil pressure enters the motor through the lifters, oil jets, and the orifices in the plate. Make those holes bigger and you are simply dumping more oil into the motor. From what I've seen the orifices are the same size as stock.. If bigger the crankcase case floods.
Another issue that some think that going to a bigger oil pump lowers engine temps because the oil temps are lower. This is not true. The bigger oil pumps have higher scavenge to feed ratio which simply means the oil spends less time in the motor (more pulled out quicker, level lower) so it has less chance to pick up the heat..
Old Jul 19, 2022 | 02:09 PM
Flo-rida's Avatar
Flo-rida
Think you got your answers
