spark plug broke off
Old Nov 11, 2022 | 08:02 AM
bustert's Avatar
bustert
today's plugs can last 100k miles and a mc does no more harm than any automotive engine unless highly modified.
if anti-seize is used, one dot two threads up from the ground electrode. BG makes a mica based thread lube and it works really well.
the thing about anti-seize is most think a little does good but a whole lot is WAYYYYY better. some anti-seize will actually cause the seize to begin with especially so when it is too close to the combustion heat. that said, plug holes need to be cleaned out to prevent build up.
https://www.amazon.in/Anti-Seize-Com.../dp/B00H26S494
Old Nov 11, 2022 | 08:19 AM
strych9's Avatar
strych9
Using anti-seize causes over-torquing if not properly accounted for. It really isn't recommended for spark plugs anymore.
Old Nov 11, 2022 | 08:39 AM
mjwebb's Avatar
mjwebb
mc plugs are exposed to the elements more than automobiles so subject to corrosion, etc...even see folks here who showed some ugly looking spark plugs removed from living near salt water or washing with poor quality utility water..2 years or 30 K is reasonable as they state
Old Nov 15, 2022 | 07:43 AM
bustert's Avatar
bustert
hardie har har
internal combustion is internal combustion. i doubt that hd engine can come even near a turbo engine where cylinder pressures are WAYYYYY above what hd can come to.
the only thing i can think of that would be diff is that the hd engine that is air cooled will have a tendency to burn more oil, especially so when the miles mount.
plugs can FOOL a lot of people!!!! they replace the plugs and WHALA, runs like a scalded dog BUT the real issue is still there!!!!
new plugs fire at a lower voltage level and can mask other issues that WILL crop up later. the o-scope will tell all. typically plugs fire in the 8k range and as resistance grows from many sources, the voltage will rise till the coil can no longer support them, especially under load.
that said, many people think a 50k coil fires at 50k, NOT!!!!, still at 8k range but the margin to 50k is possible as resistance grows.
exotic fine wire plugs last a long time, but still subject to failure, had the set in rear cylinder short to shell after smoking two cagers, how fast?, clock stops at 120, so i do not know, but a 5k rpm, that clock is history anywho!
got to love that sport gear!
Old Nov 15, 2022 | 10:05 AM
jake24lt's Avatar
jake24lt
Old Nov 19, 2022 | 08:12 PM
mickier's Avatar
mickier
I'd wonder how tight that sucker was installed - possibly torqued way way way too high -
Someone commented that if you had taken out the plug yourself, you'd have had to pay to fix it yourself - probably true...
I like to think that working on my OWN sweet ride, I'd have never never never over-torqued it and it probably wouldn't have been a problem... I hate letting someone else wrench on my baby... At least if I screw up something, it's on me... and absolutely I admit I don't know everything, but I know I have a deep affection for my baby - something that I suspect most paid mechanics may not share - especially as my bike ages (22 years old now!)
Old Nov 20, 2022 | 07:38 AM
roussfam's Avatar
roussfam
Anti seize on spark plug threads. Always a lively topic, right up there with what type of oil do you use. winter is coming, lol.
Old Nov 20, 2022 | 10:46 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Not everywhere...
firehawk6
Jan 24, 2022 11:23 PM
MidnightXL883
General Topics/Tech Tips
15
Jul 1, 2021 06:38 AM
Lowoilpressure
Shovelhead
19
Jun 27, 2021 07:21 PM
CoolBreeze3646
May 20, 2020 09:49 AM
sk1sk1
Jul 14, 2017 11:18 AM
