Cometic head gasket
Old 10-23-2023, 06:34 PM
Adam76's Avatar
Adam76
Adam76 is offline
Default Cometic head gasket
Hi,
If you use a KB piston (96"-103") that is STD 103" bore + .040" equals total bore size of 3.915"
If you have a bore size of 3.915"..... What size .030" Cometic head gasket would you use? Seems like they only make them for either 3.875" bore or 3.973" bore?
Thanks
Old 10-23-2023, 08:04 PM
Ohio HD's Avatar
Ohio HD
Ohio HD is offline
Cometic MLS head gaskets for 103" and 95" bore of 3.875" use a C9721 which is 0.030" thick and has an ID of 3.910". The C9894 is 0.030" thick and has an ID of 3.950". The bore size in the catalog is just that, and not the gasket ID.
Max Headflow (10-23-2023)
Old 10-23-2023, 10:41 PM
Adam76's Avatar
Adam76
Adam76 is offline
OK, thanks Ohio.
So if my piston ends up being a 103" piston + .040" oversize = 3.915.
So the C9894 with the 3.950" ID gasket would be the right fit?
Old 10-23-2023, 10:49 PM
Ohio HD's Avatar
Ohio HD
Ohio HD is offline
Yes it would be the closest that they show. Keep in mind OEM 103" HD pistons aren't available in 0.040", only aftermarket. That's why the 3.910" gasket size, to match HD OEM.
Old 10-23-2023, 10:57 PM
Adam76's Avatar
Adam76
Adam76 is offline
yes, I was looking at KB 103 + 040 pistons (not oem HD)
Cheers
Old 10-25-2023, 04:59 PM
Adam76's Avatar
Adam76
Adam76 is offline
I'm still confused.
If my piston is an oversize 103 piston + .040".... is the gasket ID i need is 3.915 (3.875" + .040").
If my bore size ID is now is 3.915" what gasket size do I use? Wouldn't the 3.910 ID gasket be too small?
Should I use the .030" oversize piston instead, which gives me a bore size of 3.905" ?
Sorry for the confusion.
Old 10-25-2023, 05:10 PM
Ohio HD's Avatar
Ohio HD
Ohio HD is offline
You would use the 3.950" gasket, just like a 3.937" 107" uses. They don't have to be sized just over the bore size, just larger. That's also why compression calculators have an input for head gasket thickness and inside diameter.
Old 10-25-2023, 05:19 PM
Adam76's Avatar
Adam76
Adam76 is offline
OK, thanks 👍
muskwa
Engine Mechanical Topics
03-07-2018 07:21 AM
Gary_V
12-16-2017 06:29 PM
brad75raiders
01-27-2017 11:39 AM
jhayward
11
03-31-2015 06:39 AM
twism_23
Exhaust System Topics
12-19-2012 03:14 AM
Quick Reply: Cometic head gasket
